I know, I know..."Never go to Wal-Mart except for toilet paper and socks"...but, I was in a hurry, the bays were empty, and since they use the same oil I've used since I bought it, I figured, "what could they possibly screw up???" Well, from the time I got back in it, something ain't right !!! I took it back to check for loose wires or ANYTHING, and they found nothing (one wire was semi-loose, but that didn't change anything)..
I drag race motorcycles and consider myself "pretty mechanically inclined", but I can't figure it out. It seems like it is choking for either fuel or air whenever I try to get on it, or at mid-range RPM. I checked the air filter and plumbing, and also changed both fuel filters, and nothing changed. If I'm on the expressway doing about 70 or 75 MPH and start up a long hill, I end up having to let off the pedal and then stomp it down so that it will downshift and continue up the grade. It also seems to drag second gear out before shifting to third, and then sometimes "bucks" at about 45 or 50 MPH.. I use this truck to pull my 24' race trailer and have never had a problem, but now, I don't think it'll even pull it. I'm losing alot of power somewhere and can't figure out where...It's almost like the Turbo's not turning, but I can hear it... Looking through this forum and other places, I see that it can be a million different things...EGR, ICP, IPR, etc, etc....Any ideas on how to maybe narrow down some of the possibilties?? Also, do the "cold air intakes" and programmers do all that the manufacturers say they will do, or would my money be better spent elsewhere?? Thanks for your time, in advance...By the way, I like this forum. I'll learn a lot..:doh:
