Are the frames the same as 4wd frames?
I intentionally bought a 2wd truck to convert to 4wd. I knew I didn't want the stock ford transfer case and I didn't want a ball joint axle so i am building what I want.
If the spring hangers won't work then I plan to use king coil overs and a link suspension for the front and a link suspension and airbags on the back.
This is a driver and tow rig.
