This is the first issue i've had with my truck in the longest time. i over reved the engine and i'm not sure if i did something to break any parts or stretched the headbolts. but ever sense i overreved my truck i have had these error codes on my bullydog the codes are as follows. error codes p0069 p0299 p0470 p1000. the engine has a rough idle until it gets upto about 130 degrees f. it has no issue starting or on long trips and it has white smoke out of the tail pipe even when fully warmed up. the coolent is full. the truck has aftermarket head bolts or studs im not sure, egr delete, bullydog 40420, and a 4 or 5 inch exhaust. but im not sure what the error codes mean. any help would be amazing! :woot: :thumb:
