How bad are we talkin? An is there any way to tell which side or cylinder?with truck at idle, remove oil filler cap, and lay it upside down on filler. If it pops off..(not by vibration, but pressure), you got issues, bud...![]()
Just replaced all orings on injectors a few months ago. Thanks for responseI think that is a sign that your injector o-rings need to be replaced.
After looking into the links, ill be looking for bent pushrods this weekend. Thanks for the help and I'll be posting pics of what I findwell, thats good news. Unfortunetly though, cant think why i didnt catch it earlier..:doh:, but your symptoms are what could be a bent pushrod. Same scenerio..cough/thump thru the air filter...
http://www.riffraffdiesel.com/mm5/m...ore_Code=RRD&Product_Code=HC73&Category_Code=
How?? Where to take it? I've done all the other work myself, can't really see taking it somewhere for compression test. How can I get a kit to do it, cheaply?Damn, not the "outlook" we're hope'n for....anyway for you do compression test/
