I have a 2004 f250 with 188,xxx. For about a month it has been rough running on "cold" starts(morning temps have been in 80's, hardly cold) and it cranks, but runs rough at idle. When i take off it has hardly no power for about 10 miles, and as the engine warms up it gets better to the point of running great. If i shut it off for more than 30 minutes it does it all over again. Bough the truck used, but i do know the egr system has been replaced(i need to delete it, i know) just tested the ficm and getting 49.5 across the board. Currently running hss in it simply because it is locally available and rev-x isnt. had the stealership scan it and said it needed #5, 2, 7 injectors. if hss doesn't fix it i will try rev-x before dropping for injectors. with the miles, should i go ahead and do all 8? any help will be appreciated
