I have the infamous lil leak on the water pump and plant to replace here real soon. The water pump, 203F, and flush the system.
My question is which whould you go with the Rotella CAT EC-1, and get the filtration system....or go with Dieselsite's Evans NPG+ for the low pressure system. If you have done the Evans, I would like to hear some results, and did or would you get the filtration system for the Evans...since it is waterless, is it necessary?
Last thing...tried searching, anyone have a link to a write up for good flush of the system. Thanks. :ford::nod:
