1 - 11 of 11 Posts
Wow that kind of rhymes..... I am in the process of either ordering a DP Tuner chip or buy another member's chip and have a few settings added, what I want to know is: With WVO, specfically with a my Vegistroke kit, will I roll smoke with it if I was to get a smoke setting, or not bother adding the setting to the chip. I know it would blow black smoke, but more of like a whiteish gray smoke it would be.
Discussion Starter · #2 ·
:bump::bump: I know someone has there chip cranked up running on Vegi!!:woot::woot:
in my 6.0 running the street tune on my SCT, i can make your truck disapear in a cloud of vegi smoke... :D
I thought with pure veggie oil you weren't suppose to run a chip?
Negative ghost rider, the fuel makes no difference with performance chips.
I run vegi oil fuel and the SCT tunner with the street tune as my everyday tune.
I dont know where I read that. There reasoning was because of the thickness of SVO and having to push more of it through the injector at a certain time. It made me wonder.
a properly heated vegi system does not have a problem with this. At 180* the vei oil is the same (almost) viscosity as dino diesel
Discussion Starter · #8 ·
That settles it, I am getting a smoke setting on my chip, hope my 7.3 will blow smoke like a 6.0 will. :woot::woot::woot::woot:
My 7.3 with an Edge Evolution blew more smoke than my 6.0 with an SCT does now, I've only got canned tunes though.
Thats the reason...Vivian made my tune for me and i asked for alot of smoke with it...
They say the added fuel from a programmer builds deposits in the CC with veg oil. Other people argue that the advanced timing of a programmer helps the combustion of veg oil. All I know is my truck hauls @$$ on the looney tune, and smells good doing it. I still get black smoke when I really hammer it, but it's normally kind of grey when it puffs to pass someone. Although, I added about 11 gallons of used motor oil to my last 80 gallon tank, and that made for some super thick black smoke. I was in a bind, but I probably won't do that again.........it smelled horrible.
1 - 11 of 11 Posts
