1 - 7 of 7 Posts
Can anyone tell me if there is coolant running through the rocker box (rocker carrier) on the top of the head? I have a coolant leak looks like its seeping out from between the rocker box and head but all my searches for leaks in that area are oil leaks. So looking for some clarification.
Thanks in advance
There's no coolant in the rocker box.
Ok is there anyway it could be coming through the head itself and leaking out that point? The green dot is where it seems to be leaking from
Care to share with the rest of the class?
Heater control valve is leaking and running along the top of the valve cover and down the rear passenger side of the motor
1 - 7 of 7 Posts
