1 - 10 of 10 Posts
I have a boost leak at the left intake plenum and was considering the riffraff aluminum plenums but not paying attention well enough i thought $299 for the pair when its each. The price now kinda makes me think twice about installing them and instead just resealing the originals. I would like opinions on this. Are the aluminum ones any advantage?
IMHO For the average guy, the plenum inserts are a good option with the factory plenums. The aluminum ones are pretty, but like you say pricey
I am just the average guy and would rather put that money into a turbo or injector upgrade. reliability is key as we pull a small camper and we don't just hit the local lake.
Unless it has changed it is for the pair. Where did you get that it was each?
https://www.riffraffdiesel.com/riffraff-diesel-billet-intake-manifold-plenums-94-03/
if you read the wordings and reviews it appears its for a pair of them not just one side etc. You could always call though.
Like I said unless they changed something you get the pair. I have them on my truck. See sig...
I c that now, i think i was looking at the amount counter where it says 1 but bellow that it does say a pair. Well damn,and i have a tube of the motorcraft sealer on way. I would rather have that viton o'ring than silicone. Thanx for pointing that out, i'll probably go ahead a go that route.
as been said, resealing factories and getting the inserts is the budget friendly option.
I like the aluminum ones as they seal with the o-ring however the supplied bolts are cheap and rust easily. I bought the first gen when they first came out and were considerably cheaper IIRC. For my current project I opted to try the Irate plenums (not installed yet)
if you ever run the CNCfab lines with these plenums; there will be fitment issues. different fittings or removal of the plenums will be necessary. Some notch out the plenums. I opted to use different fittings. as i was not going to take things apart to get the fittings in.
Vendor
dang, didn't know about the beans. Already have RR on the way...
1 - 10 of 10 Posts
