1 - 18 of 18 Posts
Im thinking about replacing my carpet in my truck or dying it cause of some spilled oil and stains.
Upon thinking about this I realized that it would cost just as much as using Rhino liner on my floors. But does anyone have any thoughts about using that inside a truck on the floor?
Good? Bad? Does it look good?
People do it all the time. It's a tough, durable finish.
I see it in a lot of Jeeps. Especially at mud bogs.
linex is top notch. herculiner takes a LOT of prep and it's a bit of hard work to do.. especially to do it right.
I agree line x is good stuff. But don't cut any corners. Prep is key! U can never over prep " well if you start to see daylight through youre floor pan I guess". But u can under prep. I've seen some crappy jobs. And they'll peel quick.
Granted, for just the floor of your truck I wouldn't get TOO crazy like I would for the bed/bed rails/rockers... but still, if you dont have a clean floor the herculiner wont stick. And me personally, I wouldn't spend $500 on line-x'ing the floor of my truck.
Line X from what Ive seen, you have to have someone spray that one don't you?
Cause I haven't seen any kits with that one but have seen the herculiner ones for $80.
As far as prep goes, I know the floor will need to be sanded real good, prolly almost to get all the paint off, then cleaned.
Any other prep I need to do?
Yes linex is sprayed in by a shop.
Make sure to just scuff the surface up with some 100grit sandpaper. Then make sure everything is CLEAN AND DRY. No dust, nothing.
Now which way would you guys go on this though.
Take the carpet out, power wash it and dye it, or use a bed liner on the floor?
The cab of your truck will become significantly louder. The padding under the carpet provides A LOT of noise dampening. If you don't mind the noise, go for it
Discussion Starter #12
I kinda think it would actual quiet it down some.
Dynamat is a sound damping product and isnt far behind on the same compound on what bedliner is.
Depends what your doing. I'd buy nice floor mats and call it a day
I agree only time rhino lining is handy is when the vehicle is used for work or offroading where you can just spray the floor out
Discussion Starter #15
Well I don't offroad or anything, but I work on a farm. Sometimes gets a little muddy on the inside.
The liner would be a lot easier to clean period than it would be with carpet.
Don't you think?
Depends... get good Husky liners and they will cup all the mud/water in. I've used husky liners on the farm/offroad/woods/hunting and they work FANTASTIC at keeping the crap in. They are 100$ set for the fronts and like $100 set for the rears. both should include a piece for the tranny hump.
Why dont you take your carpet out and replace it with a rubber floor liner like on XL models?
You can get a rubber floor liner from LMC
Discussion Starter #18
That's what I'm pretty much doing. Using some type of bed liner.
And using a rubber floor, moisture can get under it and rust.
But with this liner its a bonds with it and is your floor, not just a cover up.
Besides, a rubber floor liner would prolly be a lot more than the bed liner kit.
Got the kit for $70
1 - 18 of 18 Posts
