Im returning to stock, removing dpf delete pipe. What is the sequence for removing pipe and retuning H&S mini max back to stock? Im presuming its ok to keep the tuner plugged in to monitor temps and such.
Thanks.
Thanks.
You would have to install the dpf and all sensors prior to returning to stock. I can't see any problem using it to monitor temps in stock mode.
Whether it's retuned to stock or has a DPF ON tune installed, there's no problem using it as a monitor afterwords.
