new master/slave caused shift fork to blow
I was still have the same problem my pedal was sticking to the floor, the trans would shift through all 6 gears and reverse but you must pick the pedal off the floor. so I re-bleed the system, then the pedal got real stiff and when I depressed it it fell to the floor, pulled the cylinder out of the tranny and stuck my finger in there NO SHIFT FORK!! what caused this?
how many miles are on the truck. the origional problem might have been a worn out pressure plate, or a bad shift fork. Some of the factory shift forks did have a problem bending/breaking.
