This past weekend I replaced my oil cooler with a new oil cooler kit. Prior to the replacement my Edge Insight read 180-183 degrees ECT and 220-245 degrees EOT cruising at 65 on the highway. EOT would go up and not down.
Yesterday I went on a 1 hour trip and my ECT was 180 and my EOT was running 195-201. I am happy with the EOT temperatures, I think that they are well within normal, and the EOT's would go up and down as I would think they should. This leads me to my question.
I don't think that 180-183 is good for my ECT, I would expect to see 190-195 right? If that's the case, and assuming that my brand new oil cooler isn't defective, why the low coolant temperatures.
I did not replace the thermostat during my repairs, I did flush the entire system with VC-9 and added the appropriate amount of G-05 and distilled water. During my trip I kept an eye on the Edge and the ECT never got above 183 even when pushing it going up a hill. I'm thinking the following an need others experience:
1. Bad ECT sensor
2. Bad thermostat
3. Maybe the ECU flash level I am on (the one that buzzes the injectors after shutdown) misrepresents ECT.
1. Bad ECT sensor
2. Bad thermostat
