I'd been getting a P0672 for a while (cylinder 2 glow plug circuit open), and at first when I'd clear the code it wouldn't come back for a few months. Then, it eventually started coming back right after I started it. At first I couldn't tell there was anything wrong, but it got to where it was getting harder to start unless it was very warm so I figured I better fix it before winter gets here.
I bought the glow plugs at the dealer, and almost talked myself out of the wiring harnesses. I'm glad I bought them. I even bought the little tool to remove the glow plug connectors, soaked each in WD-40, and was as careful as I could wiggling it out. On the driver's side, two of the four broke so I was glad I had the harness at the ready.
Funny thing, when I tested the 'bad' one with my voltmeter once I took it out, it was good.
Don't skimp on the harness.
Pretty easy job, it would have probably taken me about an hour or so taking my time, but I decided to use my pressure washer and clean off the crud while I had the fender liner out. What a difference. I had a bit of crud in a few areas that I couldn't see with the fender liner in there, so it's nice and clean now. I cleared the codes and took it for a spin, and no more check engine light, so fingers crossed.
