Would it be a good idea to replace the original coolant temp sensor on a 7.3? The truck is 11 years old and has 230k miles on the original sensor. While replacing the water pump I thought it may be a good idea to change out this sensor. Any other items you would suggest to change out while replacing the water pump?
thank you
thank you
