" The rear mounts for the jump seat uses different holes which can be found under the carpet. You'll just have to cut some small holes to find the bolt holes"
This is what I saw on an older post, how hard is it to find e rear bolts for the console if there under the carpet, is it going to be noticeable after I cut the carpet to find the bolts? Any help would be great! Thanks!
