It can be done, you'd need to rip into the lock relay box wiring, know how to solder, and a couple diodes.
Find a violet/light blue wire (or pink/light blue)
Find a pink/light green wire.
Cut both wires. Solder a diode to each wire on the harness end with the band toward the harness (away from the relay box.)
connect both of the remaining diode ends to the relay box pink/light green wire. Tape the relay box violet/light blue wire (or pink/light blue.)
This bypasses the driver's unlock relay from the GEM, and puts it straight to the all unlock relay.
Use diodes to avoid blowing chit up.
