Hello everyone,
Last year I bought a 2006 6.0 F350 with 140k miles, it immediately had a no start on hot issue and quite a bit of blow by, pushing the upside down oil cap off. The truck is studded but probably was abused. I started taking it apart to fix the HPOP leak but then winter hit and I left it sitting.
Now I have 2 options as my current trucks lease is up this summer. To try to sell this one as is (unlikely to sell) or build it. I do need reliability for work so I am thinking of getting a different engine that has no blow by to start with.
Truck has issues with suspension and steering as well so I would like to keep budget for the engine under 7k US dollars if it’s even possible. I found low mileage 06 engine complete for $3,750 USD.
What would you do? What parts would you change or would you take a completely different road?
Parts that I already have so don’t need to buy or include in the budget: new icp sensor, new ipr sensor, new oil cooler, new stand pipes and dummy plugs, new stc connector, coolant filter, glow plugs, glow plug’s harnesses, blue spring kit and SCT tuner.
Parts that I think I want in the new engine build:
Studs and new head gasket, HHC oil rail cups, possibly an improved FICM, improved water pump, egr delete, check heads before putting them back on.
Looking for opinions and suggestions,
Thanks!
Thanks!
