1 - 17 of 17 Posts
I purchased a 2018 F-350 not long with 12,000 miles on it. I keep reading about the "Regeneration Process" but I never seen anything as described. I'm a former 2002 Dodge/Ram owner and this is all new to me. I've looked in the information display on the dash and there's nothing I can find there. I've driven the truck about 2,500 miles since I bought it and it's run perfectly...LOVE IT. But I have never experienced any "regeneration". What am I missing? Will I experience anything to tell me I have to do something or is it automatic if and when it goes into "regeneration"?
Thanks from a newby.
There is a message that pops up on the dash for a few seconds when it starts. 6.7s generally regen about every 300-500 miles depending on driving habits. If you are doing something wrong, you will see a message that stays on the dash saying drive to clean exhaust.
You can download an app called torque pro on an android device and use a bluetooth OBDII reader to monitor the truck or buy a monitor like the edge CTS2. You can watch a lot of different engine parameters including emissions. It will tell you when the truck is in regen.
If you aren't getting a message that stays on the dash, you don't need to worry. I can generally feel when my truck starts a regen, its a lot more subtle than my 6.4 was though... The only annoying thing is, even if you see the message you have no way of knowing when its done without a monitor. Its always a good idea to drive it until the regen is complete (usually about 20 miles).
Long story short, if you are worried about it... Get a monitor (its a good idea anyway), but the truck will do its thing and tell you if you need to do something different. Just try to limit short trips as much as possible.
Reactions: Blue2018-350
I just bought my truck and have put about 1000 miles on it so far and haven’t seen any messages or felt anything that I would call a regen. Also the DEF fluid level hasn’t changed. Probably 60% highway, 40% city driving.
But I figure the truck would tell me if I wasn’t allowing it to happen or something.
Regen procedure? You put def Fluid in dude
There is another process happening too, it’s called combustion. You add diesel to support it’s continuation. You don’t fret that right? Just keep the Def tank supplied and don’t Worry about it. Only keyboard commandos care about tracking And watching regens. It boggles my mind. Somebody should make a light that notifies you when exhaust recirculation is happening. I’m going to delete all that crap when I can find the time to get to it
I don't know what's up JetJocks rear end about this, but I can tell easily.
I usually keep the instant fuel mileage screen on. When I'm doing 75mph, I'm usually seeing it hovering around the 17-19mpg area. When regen starts, it will stay at 10mpg or lower. In the area I live in, there's a lot of 60mph zones. MPG is usually at 20 or above. 45mph areas, 25 or above. However, when in Regen, it's at 10mpg.
When pulling something while in regen, I don't see above 5mpg.
As soon as regen is over, the MPG reading goes back to normal.
Hawk do monitor the sunrise to ensure the sun rises? Would be as productive as watching regeneration.
Maybe I will develop a sensor and display to monitor EGR. I could make a ton selling to ya’all. Muffler bearing friction display and rpm too potentially. Hmmm got me thinking
:look:
Dono what that was about... It is always good to understand what is going on with the truck. As I pointed out, the truck will tell you if you aren't letting the dpf clean completely. If enough regens are interrupted and it fills up enough, the truck will keep a message on the dash saying drive to clean exhaust. It isn't something to stress about, but there is nothing wrong with keeping an eye on it.
Either way, if you know the truck is in regen... Its always a good idea to let it finish if you can. And there is nothing dumb about watching the dpf status. Its really annoying not knowing when the dpf is full, or when its done cleaning the dpf. A CTS2 will tell you when its in regen with a little green light. Its kinda handy.
Its also a really good way to tell if there is a problem with the truck. If you usually average 400-500 miles between regens and now all of the sudden you are going into regen every 150 miles without any other changes to drive habbits..... You know something is up.
WOW, sorry JetJock15 for wanting to know whats going on with the truck. I've had diesel trucks before but not one this advanced and one that has so much technology. Guess I'll wait to see what message pop up in the display. So far, nothing, and I've put over 2K on it since I became the owner. And no change that I can see in the MPG.
Right here is your answer and you dont need anything else. I also put the regen page into my selection with forscan. Watched it in the beginning to understand it and now never look at it any more.
Why bother with routine maintenance by your line of "thinking"? Why do through-flight checks? Why monitor fuel burn rates? I mean, it's like someone kinda smart figured out that if you kept track of what the aircraft (vehicle) was doing on a regular basis, you could almost prevent catastrophic failures by monitoring integrated systems and their overall health. Stop being an ***.
Don't even bother. He has a stick up his butt and refuses to see why it's beneficial to the overall dependability and performance of your truck to ensure systems are operating properly. I mean, God forbid you recognize a pending malfunction that could put you into reduced power mode while towing a heavy load hundreds of miles away from home before you ever leave on that trip. :rolleyes:
I have about 11k miles and haven’t seen a pop up message about regen. It’s not a huge deal but if it’s not telling me when it’s happening, how do I know that I should not turn the vehicle off and interrupt the process?
You don’t need to worry about interrupting regen by shutting down KingRanchDude. That was only an issue with earlier models as well as the associated display. The new models don’t require ANY user input (more than adding DEF) so thus there is no display. Technology advanced, these keyboard commandos just can’t Phathom it.
Hawk, as per aviation references it’s a good train of logic but over the last 30 years the focus has shifted from “knowing all systems” to “knowing the systems you can effect”, brought on by new technologies being Uber complicated. In all Honesty, sorry for coming off like an a$$, I get your point, I just think you all
Mis-guide newbies into thinking this is something that requires user input. It’s holdover from older models. If ford deleted the display they obviously overcame the need for user input with new technology. This is the reasons these forums are divided by year groups. Though the 17-19 models had changes within the year group, I think you misguide 19 owners with logic that applied to 17s. Your assuming millions of miles of testing, all the engineering and R&D of FoMoCo, with all the warranty $$$ as the wager, was inaccurate or incomplete, requiring you to get out there and educate 19 owners on the requirements to monitor Regens, requiring software changes that are not included with the truck? That’s insanity bro. Keep monitoring the sunrise brother somebody has to make sure it rises, I applaud you
I still can't decide if any of this is directed at me... If so you have clearly lost your mind.
As stated before, if the truck isn't telling you anything... Just put your foot down and go. If one wants to know whats going on, get a monitor. You of all people can't sit there and tell anyone that a monitor isn't worth getting.
And either way, it is absolutely not the best thing for the truck to shut it down in the middle of a regen. But, you can't avoid it all the time and Ford factored that into the design.
You said you plan to delete, so there is no reason to be concerned with the dpf. For those that don't want to or can't go that route, its in their best interest to let regens complete. If nothing else, the dpf will last longer. So will the turbo......... But hey, I am an internet warrior just trying to spread fear and misinformation after all.
Reactions: Hawk388
The 17+ don’t have the display that pops up when it starts. The only indication is the drop in MPG. You can have the DPF status screen enabled that will tell you the % full it is. When it is 100% full you know it will start soon.
Reactions: jd4010
First off, I partially agree with you about not worrying about interrupting Regen's. My caveat being, if you've interrupted it a couple times, for me I go with two times, then on the third I make sure to drive until it's complete. That's not written anywhere, just my personal idea. As mentioned by someone else, I think it's just much better for the turbo from what I've read.
As far as your R&D and warranty comments, there are hundreds of dead people who would disagree with you about being knowledgeable of all systems. Especially ones where a manufacturer doesn't think you need to know much about them. Boeing is currently making sure pilots know a tiny little sub-system a whole lot better.
I'll point out the OP asked a question. I simply gave him the answer to that question. I never, not once, told him or anyone else what I thought they SHOULD do, nor did I try to "educate" anyone any further than to answer the question of "How can I tell when my truck is doing a regen". Due to your desire to be insulting on the topic, your need to come across as smarter and thus, barely tolerant of others who just "aren't on your level" as well as repeatedly being insultingly dismissive, is informative as well as what has been said on this topic.
Just so you know, my career was in rotary wing platforms. There may come a day where you're only concerned about systems you can directly influence, but that certainly isn't today. To ignore secondary and tertiary system warning signs, whether directly influencing operation or removed, is to be an annotation in the annals of aviation deaths. I think it's cute you so readily place enough trust in how something is designed you simply ignore things.
Unless I am mistaken the drive to clean message will still pop up though once the dpf reaches a certain level or hasn't started a regen after a certain number of miles/engine hours. Its a message that stays on the dash and doesn't disappear unless you click ok.
I was unaware that Ford did away with the short message all together... Thats annoying.
Either way, as stated before... Not really worth stressing over, but absolutely worth understanding.
I am pretty certain you are correct about the drive to clean message. I believe there is also a message saying it is in limp mode or something and the dealer has to clean the DPF. It can't be cleaned from driving.
1 - 17 of 17 Posts
