Hi,
Any recommendations on a trustworthy shop to do heads on a 2003 Ford 6.0? I expect I need the heads resurfaced, new gasket, and head studs.
I plan to test my coolant pressure under load after seeing coolant pool around cap. I thought about replacing the original degas bottle but if the pressure increases under load then it may be the head gasket.
2003 Ford Excursion 6.0
New Ford 6.0 degass cap, only ELC coolant, coolant filter, aggressive maintenance schedule. Runs well.
No coolant and oil mixing.
No coolant in exhaust.
Test of coolant at idle did not show exhaust gas.
@bismic
@bismic
