Rebulding my Fuel Bowl, FPR and Drain Valve, as well as all short hoses above the valley. I've got some pretty bad leaks, to the point that one is dripping once every two seconds.
First problem: there is no spring in my FPR Filter Screen Canister. I'll have to order one...since the truck didnt have it for who knows how long, I guess a few more days wont hurt anything.
Second problem: I was...ahem... trying to re-install the connector to the Fuel Heater Element and the entire "wire" heating element came off. No damage, it just came off. How is this re-attached? Solder?
I read this thread and decided "while I'm in there..." and did the BB mod:
http://www.powerstroke.org/forum/7-3-mod-help/31197-obs-fpr-shim-gauge-install.html
Do I need a Fuel Pressure Gauge in order to use this mod, or can I run without a guage for a while?
Anyways, thanks in advance for any advice. Hopefully I'll finish it up tomorrow and do a leak check.
