2014 f450 platinum, the rear window defroster is having issues. The 2 side glass, only 1 strip on each side is heating up, the 2nd one down from the top. The center power slider all of them work. See no visible issue with the circcuits or connnections. Any tips on how to trouble shoot, fix said issues?
I don't know how the circuit is run for the slider from the stationary glass but that sounds odd. Trying to explain the troubleshooting is too wordy but I found a video that may help. It's exactly what I did on the wife's VW. There are repair kits at most auto stores. I used the Permatex flavor.
Sounds like yours is not just a grid repair though. But I hope this helps.
You may have to replace the rear window. Safeflite has them. I paid about $300 for mine. I also got OEM one.
Thanks Guys for the info, will check it out this weekend with a meter,. May have to go the replacement route
