1 - 5 of 5 Posts
so on my cc f350 my passenger rear power window will not go up, it goes down but not up:dunno:. its not the switch i tried a new switch. its not the motor, just put another one in it. so im guessing there is a short in the wire somewhere. is there any common places for this to happen a maybe a fuse:confused:? thanks for your help!:thumb:
Had the same problem, are the lights in the switches on when the truck is running? mine would go down but not up and the lights did not work in the switches, i had to replace my driverside door controls because that panel turns the switches on and off...
Does it even try to go up? Is the motor working and binding? Or is there just dead silence when you try the switch?
its dead silence when i hit the switch, and all my driver panel lights lite up but i would have to check the plug in the back i have it unpluged so no one rolls it down and i cant get it back up.
I had a similar problem last year and fixed it. It was the front passenger window and found the problem to be in the drivers side switch. Took my father-in-law 10mins to find the problem after I spent hours on it. I fixed the switch because I was to cheap to buy another and it's been good ever since. Not sure if it's the same problem but have a good look at the drivers side switches. Hope that helps.
1 - 5 of 5 Posts
