1 - 9 of 9 Posts
My truck is a 99 dually with a dana 80 rear. Its got a lot of miles and needs somework.It still works ok but has some clinks going in an out of gear.
anyway, I found one from an 03 dually. I am pretty sure it still bolts right in and lines up with the leafs.The issue is My drive shaft attaches with strapsand 4 smallbolts.
The 03 rear attaches with the newer type circular brace that gets pressed onto the existing u joint. Then has 4 12mm(i think) bolts holing it onto the rear. How would i go about making this match? Add the new yoke to my driveshaft?
can I just swap yokes on the rear? Want to swap these? wanted to check this info before i spend the money
thx
You can probably get the matching yoke for that rear end and put in on your drive shaft. Just make sure it wont make it too long. A local drive shaft shop can set you up straight and should have a old yoke layin around.
I was hoping to take the yoke from the 99 rear thats in my truck and put it on the 03 rear. I was wondering if anyone knew if the splines were different? I looked up ring and pinions. They offered them but not with different splines?
The 03 rear's yoke stops even with the pinion threads. Mine(yoke) comes about about3/4 inch farther? I almost think I can add the mating part to the shaft or change yokes?
I was hoping someone could tell me I can just change yokes, its iterchangeable. Someone here must of swapper rears?
Powerstroke Junkie
As long as the gearing is the same you should be able to swap the yokes. 99 used 3:73 and 4:10, and 03 was mainly 4:10 for duallies.
NCH
i think my 99 is 3:73
the 03 rear is a 4:10
does that mean yokes cant be swapped?
if you have a two wheel drive the ratio isn't an issue, but if you have a 4x4 the front would have to be swapped to match the rear end ratio
can i get a good explanation on that?
if the rear is a 373 then the front diff is the same? Never really thought of it.
hmmm, maybe I am better off fixing what i have. scuffy828 on here can do it.i am close to him. I need to checkmy gear ratios, You mark the rear yoke right, and see if with one wheel revolution, how many times the yoke spins? either 3 3/4 times are bit over 4 times right?
Powerstroke Junkie
Yeah that's right, fill out your location so we know where you are located. I am also near Scott, just north of him in Mt Airy.
NCH
1 - 9 of 9 Posts
