1 - 9 of 9 Posts
Powerstroke Tech
First off I know next to nothing on rear ends. I have a 03 f350 when I power brake the truck in drive I only get one wheel to spin. Is this normal with a posi or are the clutches in the rear shot ?
Powerstroke Tech
Iam not a big fan of the one wheel peel. Debating how to go about eliminating it. Do I try to change the clutches or go for a locker
It'll be less expensive to repair the factory limited slip, but eventually the clutches will wear out again and you'll be doing the same job over. I went with a TruTrac partially because of that (no clutches to wear out). The other reason was that the TruTrac will outperform the limited slip all day, every day.
Personally I prefer the True Trac up front and a Detroit Soft Loc in back as I've found under some icy conditions that a True Trac can unexpectedly do a one wheel spin.
Sent from AutoGuide.com App
Administrator
Ford Certified Diesel Tech
03 F-350 Crew Cab short bed
6.0l
Arp studs
XDP Coolant filter
Sct Sf3- idp tunes
Silverline staintless turbo back 4"
not installed:
XDP egr delete
Curious ? Whats Staintless ? :rofl:
Fuel it up again Dummy
You can always change the oil in it. Look at what's left in the pumpkin as far as metal shavings, if it looks good may be like zman said just too much slip modifier in the oil.
If you want big time posi-traction aftermarket is what you want.
1 - 9 of 9 Posts
