1 - 20 of 36 Posts
Guys is there just one eye to refill the axle, and do you remove the old oil by unbolt the cover. Thanks
Administrator
make sure you replace with the spec'ed weight in synthetic and you may or may not need the LS additive .. if you have chatter when turning you ad some and let me tell you keep it off your clothing and seal the bottle and bag it when done ,, it stinks
Is the gasket reuseable or not. Thanks for the help
Administrator
if u have the aluminum cover just use RTV silicone the cover has a grove for this
actually RTV will work on the stamped steel cover also just get everything clean.
scoop out the pocket under the ring gear real well it tends to hold some debris
Do you guys know what the foot pounds for the bolts are.
Winning DUHHH
Not off hand, just tighten it in a star pattern I'd say 15 ft lb but on something like that I wouldn't worry about torquing them
Administrator
ya i just go for tight is right and do a pattern of random sort to get the sealant to disperse evenly
How long are u guys wait for the RVT seal to dry before addi.g your oil
Administrator
i waited about a 1/2 hour and that is probably a 1/2 hour longer than a mechanic would wait LOL
Don't you worry about it
This is a true statement. Quick stick it and keep on kickin it.
Discussion Starter #13
Thanks guys got it done everthing looked good hopefuly the oil stays cleaner with the Amsoil 75W90 oil.
The oil won't stay any cleaner. Maybe just hold up longer.
And was that the weight rating for the oil from the book?
Winning DUHHH
75-140 syn isn't it
Ya I did a quick search and I think the spec is 75-140, I know the front diff is different something to the tune of 70-90. I don't know what the book says.
Sent with my mind using ESP.
Discussion Starter #20
Whats the difference between to 75\90 and the 140. I ran the 75\90 in my one ton ram all the time
1 - 20 of 36 Posts
