The rear A/C could have a leak and the front work fine. Need to have dye put in the system and recharged to pinpoint the problem. Probably one of the lines that run to the rear causing the issue.The rear a/c in my 01 is not blowing cold? Front works fine.
It's one compressor but there are front and rear lines. One of the lines is probably leaking.I think it is a one compressor system?
Not necessarily. I've seen front work and the rear not and all because of a leak. Take it and have the system evacuated, have dye added and then recharged. Run it for a while and take it back to see if the dye appears anywhere. I guess it is also possible that the blend door for the rear is not switching either which will keep the air from being cold. I just know that I have seen a lot of lines leak causing the problem.Ok if the system was leaking wouldn’t the whole system get low on refrigerant? thus the front would not work?
No problem. I really don't know about the blend door location.Thanks for your help. What is the location of the blend door for the rear ac?
This Issue is back again, I did remove a plastic bag from the air return vent in the rear at one point and the volume of air increased. Has anyone else had issues with there rear A/C?
