1 - 5 of 5 Posts
as the title says then my 97 f350 started to run very rough and has no power. i drained the fuel bowl and some water came out with the diesel but still the same. any help will be greatly appreciated. john stelly cuernavaca mexico.
You may have picked up junk from the tank or you have air in the line, How was your filter.
Replace the filter, Add Sea Foam and start. then run the crap out of it.
If there is air in the line it will do the same thing.
thanks for the fast reply. your advice sounds right. what is sea foam?
your advice worked like magic! i removed the little purging valve which had some trash in it causing it to leak and not seal well. after installing it the truck started up and runs better than ever. thank you so very much.
1 - 5 of 5 Posts
