This is the third time this has happened in the last year. I have no power to my radio, windows and mirrors. Any ideas before I send it to the shop again.
The gauge cluster is the #1 cause of this. You can also check for loose grounds under the dash.
I am proud to announce. Researching I found square fuse #10 and Fuse 42 to be bad, inside drivers side next to steering column.
