1 - 11 of 11 Posts
Since I dont know the history of my transmission what type of fluid would you recommend ?
How bad would it be if I mixed the two unknowingly?
Oreillys computer said Mercon LV but I thought it was Mercon V.
Mercon LV. Should probably change the filter too
It is NOT Mercon V.
I get the Mercon SP, but LV works also. Even the Valvoline MaxLife has proven to work.
Ford has gone back and forth a couple times on this, but i'm with @bismic and use Mercon SP.
-jokester
Administrator
Ford never went back to SP for the 5r110 but they did revert for a few other applications and that's why they never phased it out like intended
but they did not suggest mixing SP and LV right away then they came around to approving
a lot of guys use the Valvoline High Mileage SV/LV fluid (it is not a Mercon approved fluid just Valvoline suggested replacement )
They are back to recommending LV again but the SP has treated me good for 15 years so I'm going to continue to use it
Sent from my SM-G960U using Tapatalk
You're not supposed to mix them though
Administrator
our service interval is a lot less with the SP than with transmissions that had LV as the original fill
you have to wonder if any of that is fluid related ? or all the filter type ?
Personally I believe it is the 100% filtration.
So my tranny pan has a drain plug in it so Im going to just drain that out for now and refill it.
Approximately how much fluid will I need?
8 qts
I do a series of 3-4 drain and refills every 30k miles (I drive it enough to get the fluid hot and have enough time to mix in between each drain and re-fill). It has been good for 215k miles.
1 - 11 of 11 Posts
