1 - 5 of 5 Posts
Anyone running a Looney Tune on stock bolts still? If so how is the tune, have you had any problems from it, and how long have you been running it? I was looking at either the looney tune or ecocity tune until I do studs hopefully next winter (if all goes as planned). I have an ‘03 f250 with 4” turbo back exhaust, blue spring, coolant filter and soon to be back flushing the oil cooler and switching to elc coolant.
ive been running looney on stock bolts for around 40k no issues, it an 05 with 170k never had a gasket issue its got a kc stage 1 turbo, 4inch turbo back, s&b intake, blue spring, coolant filter, egr delete.
the "looney" tune is built for stock bolts,, the "looney wild" is for studded engines. that being said 244k on my stock bolt engine running the "looney" for 30k----- no issues
My truck has the stock bolts with 114k miles, been on the looney tune for about 10k miles and no issues so far. I did do oil cooler and coolant filter, but it has nothing to do with the tune. Other than that its stock.
Makes a big difference in performance.
Just got the looney tune on bolts about 600 miles ago. I was previously running innovative performance XS tune (it’s their hottest for stock bolts, so about the same equivelant). Driving experience, night and day. I really like the looney tune. Smooth on the shifts, doesn’t smoke until you hit it hard, and gets you going; egts seem to run slightly lower than the innovative tune too when hitting grade.
04 f250. KC stage 1 turbo. S&B cold air. Banks 4” turbo back exhaust/cat deleted). Etc
1 - 5 of 5 Posts
