Color issues with wiring power mirrors?
I'm trying to wire up a set of power mirrors on my dually. Trouble is, the wires coming from the door harness are purple, green, and yellow and the wires on my mirror are red, black, and dark blue. I've been unsuccessful with getting the correct combinations and end up either blowing the fuse or the mirror only wants to go up and to the left regardless of which way I push the switch. Any suggestions?
There's no link in your post.
2008 mirrors - Here's a quick run down of the 08 mirrors to 06 mirrors wire color conversion schematic if you cannot open the pdf version of the document posted earlier in this thread.
http://www.powerstroke.org/forum/me...mirrors-into-1999-2007-sd-trucks-oem-way.html
P/N 3U2Z-14S411-DLA *see also WPT-219* <--- switch wiring/plug harness
Driver's side:
08 mirror 06 mirror
-Red w/ Silver tracer -Red
-Yellow w/ Silver tracer -Yellow
-Blue w/ Silver tracer -Blue
-Mint Green -Green
-Black -Black
-Black w/ White tracer -Black w/ White tracer OR Green w/ Purple tracer
-Brown -Brown
Passenger's Side:
08 mirror 06 mirror
-Green w/ Silver tracer -Green
-Purple w/ Silver tracer -Purple
-White -White OR White w/ Blue tracer
-Black -Black
-Brown -Brown
** Wire colors for Power-Fold & Power Telescoping functions were already posted earlier in this thread.
Here's the link I used for the relays in order to get the 08 mirrors to reverse the operation of the left/right functions and operate properly. It might look sort of confusing, but it was really simple to do.
Wiring fix
As far as the switch wiring(mine already had 7 wires uand fit into the 08 mirror switch). I just added the 8th wire that I took out of the WPT219 that I ordered.
If you flip the switch upside down so that you are looking at where the connector plugs into i will base my colors like this...
1234
5678
1-Black
2-purple
3-orange/green stripe
4-black wire I added
5-blue
6-yellow
7-green
8-red
Here is how I hooked up the wiring coming from the 08 mirrors to the stock wiring coming from the door.
08 mirror.......................................OEM
_______________________________________
Driver side
mint green----------------green/white stripe
black/white stripe---------green/purple stripe
black---------------------black
yellow--------------------yellow
blue/silver dots------------blue
red-----------------------red
brown--------------------brown
Passenger side
yellow-------------------yellow
white--------------------white/blue stripe
black--------------------black
purple/silver dots---------purple/brown stripe
green/silver dots---------green
black/white stripe--------green/purple stripe
brown-------------------brown
http://powerstrokenation.com/forums/showthread.php?t=79720&highlight=wasgas+08
http://powerstrokenation.com/forums/showthread.php?t=64252&highlight=wasgas+08
Sent from AutoGuide.com App
I could totally be missing it but I'm not seeing a situation in your post like the one I have? I have just regular old non tow power mirrors. No defroster, auto folding, telescoping or any of that jazz. Just a 3 wire hookup for adjusting the mirror up down and side to side. I don't have any special wires with lines, dots, or tracers. Here's what I'm working with:
Truck Wires:
Green
Yellow
Purple
Mirrors that I'm installing wires:
Red
Black
Dark Blue
I'm just trying to figure out which color goes with which color. I don't understand why the colors are different anyway.
