1 - 2 of 2 Posts
· Registered
Im thinking of swapping out my TTB for the dana 60. Right now the ride in my truck is pretty stiff it has the original shocks which prob doesn't help and i heard the add a leaf makes it stiffer. Im not having any problems with it i just know i will one day. Does the dana 60 give you a nicer ride? Is it worth doing my truck is a daily driver it occasionally goes off road nothing crazy
· Rangers Lead The Way!
Its well worth it. Even doing the 60 swap with stock leafs helps. To add to it using 350 front leafs makes it better. The best bet is an Rear shackle conversion where you run super duty leafs. They are longer and ride much better
1 - 2 of 2 Posts
