New to the forum and just got out of the intro forum. I recently bought the truck in my signature and I have a quick question. I owned a cummins previously and that thing took a good while for the temp gauge to move off the cold mark (even in warm weather). My 7.3 Powerstroke seems to warm up really quick. For example, 62 degrees this mornin, I started it up and let it idle for 1 minute. Then eased out of my complex onto the street to the stop light. Only a 1/4 mile at no speed over 20mph and the needle was already off the C line. The cummins would've taken about 3 more miles at 45 to move. The truck doesen't overheat, I was just wondering if this is the norm with a 7.3 or is there an issue. Any advise would be appreciated!
Not sure why everybody thinks the cummins is the holy grail of trucks. My powerstroke starts far easier than my cummins ever did, gets warmer faster, and controls egt's better.
Now when its 15 degrees outside...its gona warm up like a diesel. My drive to work is 25 miles. There is a steep hill climb like 5 miles from my house. Once I climb that hill, then I have heat.
Very true. When its 30* and colder its gonna take a bit longer for sure.
My 05 Cummins took FOREVER to warm up. It literally would be 15-20 minutes before I had heat on a 25 degree morning. My 02 7.3 takes about 5 to produce the same amount of heat. Totally normal, although I do find it weird as the 7.3's cooling system is larger and the motor runs with lower EGTs than the Cummins. My Cummins would easily hit 1,300 on hills that my 7.3 only gets to 1,000.
My cummins took forever to heat up also. Although heating up has little to do with radiator efficiency; it has to do with the ecu being programmed to run the tstat/ebpv. Also, we're comparing a baby 5.9 cyl to a 7.3liter v8... which sounds like it will more obviously create more heat?
BTW, I'm also inclined to not believe that a powerstroke has a less efficient radiator simply because most cummins in
stock form will get to the "hot zone" in egt's by simply dogging on it. Most powerstrokes can take some ample mods before they get anywhere near the hot zone.
Exactly, so you would think the Cummins would warm up quicker since it pushing more fuel and runs hotter. But it's not the case, the cooling system must be more efficient than the 7.3s. I am not complaining though, it's nice to have a warm cab in 5 minutes instead of 15.
read reply above... not inclined
whatsoever that a cummins has a more efficient cooling system.
