1 - 2 of 2 Posts
I am looking at a 95 Ford PSD. It has 186000 miles on it. Has the 5 speed manuel tans. and the cluch has been replaced. The ball joints have been replaced. What else should I look for?
What is the difference between the the motors from 95-99?
I know the 95's were rated at 225 hp, how many lbs-ft of torque did they have stock?
thanks!!
check the turbo for fin damage and shaft play. check for leaks, thats about it.
starting in early 99 (98), they used electric fuel pumps and i think split shot injectors, different IDM and ECU iirc, and intercooler. Late 99 (actual 99's) had 17* hpop, larger split shot injectors, as well as various other components.
my 95 is rated at 210 HP and 420ft lbs. i find psd are a good rule of double. so it your at 225hp a good estimation would be 250 ft lbs.
1 - 2 of 2 Posts
