I have a 97 F250 4x4. Alright, I have read post after post and I have done everything I can think of that would cause the truck to pull to either direction.
Truck originally started pulling right more under braking, bled the brakes and that did not solve the problem so the truck has brand new brakes all the way around (calipers, rotors and pads) and they have been bled multiple times. It was still pulling right while driving so I spent all of Saturday doing ball joints, bearings and races in the front end. Yesterday it had an alignment and if anything that made it worse. It also has brand new shocks on it as well and fairly new tires that have even wear.
I simply cannot figure out why it keeps pulling right. Help is greatly appreciated. I thought maybe I put the hub together wrong causing the right side to be engaging in 4x4 but that is not the case. The only other thing I can think of is tie rods but they don't appear worn and are greased regularly, but would that make it pull right pretty hard under normal driving? Yes, I know I need a dana 60 but funds prevent me from doing the swap for now.
