1 - 20 of 23 Posts
Stupidity pisses me off
My truck has had an intermitent "knock" at idle for awhile. I finally got around to scanning it. I have the AE ScanTool with the total Ford bundle.
I ran two injector buzz tests and both came back clean.
I then ran a cylinder contribution test and it came back with two codes:
P0269 Cylinder 3 circuit contribution/balance fault
P0284 Cylinder 8 circuit contribution/balance fault
Other than the rare knock at idle it seems to run fine.
Any ideas?
Thanks,
Adrian
Discussion Starter #2
:bump::bump:
:bump::bump:
:bump::bump:
Black or Gray CPS?
I had the recall done so it's the grey one
The grey one will cause those codes randomly:doh:
So I should replace it with a black one?
Does anyone know if any org vendors sell them?
try diesel site. I know some dealers sell the blue one from international and that is suppose to make a dramatic differnece over stock
Discussion Starter #13
Thanks, I'll give it a shot!
Can I just buy the blue one from international? There is an international shop here in town.
Discussion Starter #14
Has anyone here installed the blue CPS? I've been researching and from what I have found the black one was made as an upgrade to the blue one.
The blue one is actually for the DT466 engine. It works in a 7.3 but it also retards the timing
:agree:
I wouldnt run the blue one unless it was my only option. It will retard the timing about 4*
Unless you tell your tuner you are running this so they can correct the matter I wouldn't do it.
Discussion Starter #17
So it sounds like my best option is to find a black one?
Been wondering about this myself.....had similar code on Cyl Contribution Test, exept #8 only.
I think this is where you tell me that the International part # 1821720C99 for a black one is no longer available (on Guzzles site where he mentions the gray CPS problem).
Guzzle's CPS R&R page with Info about Gray CPS Issues
Discussion Starter #20
Does anyone else have any input?
1 - 20 of 23 Posts
