1 - 7 of 7 Posts
Hi,
When you mention the coolant "puking", how much are we talking about to consider it a problem? I have just a couple of small streams of white from my fill cap. Is that something I should worry about?
You may just need a new cap for your coolant reservoir. I know some people had problems with them not sealing well
I think when you have a real problem they puke alot of coolant
Thanks! Nice truck BTW :icon_ford:
when it's puking, you will see all sorts of coolant sprayed around your driver side wheel well, and the coolant level in the bottle will go down quite a bit.
watch your coolant level...i just took mine in for a headstud job and the only thing that was visual was a little bit of coolant streaming down the degas bottle.
Discussion Starter · #7 ·
wow. and the gaskets were blown?
1 - 7 of 7 Posts
