hello everyone
Recently picked up a 2006 Ford F350 4x4 and i want to refresh the entire front/rear suspension system and all the components involves in the way the car drives, turns, handles and feels on the road.
Whats is the best place to source parts like this? everyone was talking about motorcraft for all the engine related stuff but i dont see any info on manufacturers for the mechanical, i saw some suspension kits on ebay but not sure about quality. where do you buy your stuff?
Anyone want to help me compile a list of the must have items required to make this truck drive like new? Appreciate you
Discussion Starter #2
Hope all is well
Recently picked up a 2006 Ford F-350 Super Duty Lariat Crew Cab LB 4WD , got a steal from my cousin , needs a ton of work but i only paid $2500 , 165k miles.
Body work: see photos
772432
772433
772434
772435
772436
Interior:
New carpet
Full detail
New seat covers (to cover the some of the ripped leather - will probably get better leather ones later)
Wheels/Tires
  • 4x LT275/70R18 125/122R E MICHELIN DEFENDER LTX M/S
  • 18X8 OEM wheels (text me if you have for sale)
Engine: (i created another thread to get help on this list and create a solid list of MUST HAVE items and this is what we came up with for the stage1 bulletproof and all the other odds and ends)
  • FORD ORIGINAL ENGINE OIL COOLER 6.0 Diesel Kit-3C3Z-6A642-CA
  • Bulletproofdiesel EGR Cooler + Appropriate Gasket kit
  • Ford 4C3Z-9B246-F Fitting Update Kit
  • 6.0 Blue Spring Kit Upgrade,Ford Blue Spring Kit 6.0 Powerstroke Fuel Pressure Regulator Kit
  • Stant 10238 Radiator Cap - 16 PSI
  • OEM Ford / Motorcraft Set of 8PC ZD-13 4C3Z-12A342-AA Diesel Glow Plugs 04 - 10 Ford 6.0L + Harness
  • Mishimoto MMCFK-F2D-03BL Coolant Filter Kit + Rotella ELC Antifreeze/Coolant Concentrate ( 2 concentrated gallons)
  • Genuine Ford 6E7Z-9A332-B Fuel Supply Tube (STANPIPE + DUMMY)
-Schaeffer's #700 SynShield Durability Advantage 15W-40 4 gallons + Motorcraft FL2016 Oil Filter
  • Motorcraft FD-4616 Fuel Filter
  • Motorcraft FA1778 Air Filter
  • Motorcraft Injector Control Pressure Sensor (ICP) | 6.0L Ford Powerstroke
  • New OEM Ford Motorcraft CM5126 Fuel Injection Pressure Regulator Free
  • Genuine Ford Oil Pressure Sending Unit F81Z-9278-AA
SUSPENSION :
So heres where i need some more help , but im going to create another thread now to ask about this list ....
pls let me know if anything you're seeing sticks out and you think i can improve somewhere
appreciate your help
Looks like you covered an initial build well. My one suggestion is don’t waste your time with the factory oil cooler. If you can afford it do the bulletproof heavy duty cooler with cold weather kit. I have done a lot of 6.0s and the bulletproof cooler kit is hands down one of the best mods you can do to a 6.0.
Discussion Starter #4 (Edited)
unfortunately that is not going to be possible
