Hi,
I've got a 97 f250 ECLB 4x4. While I'm pretty mechanically sound and would like to think I know a bit more about cars than the average person, I'm relatively new to diesels (~2 months experience, 1 month of ownership of this current truck). These are my concerns (only engine-side; the rest of my issues I can pinpoint because other vehicles have them too) that I'm having with my engine. It's got 330k, bone stock (it looks like the turbo and downpipe have been replaced), and it makes typical 7.3 5 speed power, and gets 20mpg highway. It'll still get up to ~93mph until I run out of gearing, too. So the engine's not "unhealthy." I've cold started it(plugged in) at 10 below and it took maybe 2 seconds of cranking and it started right up.
-I'll be the first to admit it: I accidentally put regular 50/50 ELC in my overflow tank, and wouldn't be surprised if I mixed it. I'm gonna do a water pump and Tstat soon and a full coolant flush and then run a ~65-35 mixture of fleet charge. This is temporary (less than 3 months)
1. Temp Guage doesn't move
Granted, I bought this thing in the dead winter in Colorado and it's been -20F almost every day here. I keep it plugged in to keep some heat in it. However, I took it on a 4 hour road trip and it did GREAT, but the temp guage hardly EVER went past the "n" on normal. It only went to the middle climbing a mountain pass and went right back down as I let off throttle. I will soon replace water pump and put a 203 thermostat in it. I wonder if it's just cuz it's a really beefy cooling system or just because I haven't driven this truck in any weather higher than 35F.
2. Stiction?
Prev owner said the glow plugs were replaced. My coworker has informed me that often times people will only replace one bank because the other is hard to access. I wonder if this is the case. When not plugged in, at ~10F, it still starts within a couple seconds of cranking, but the injectors are LOUD and the entire truck shakes. The rear wheelwells rattle like there's no tomorrow. Changing to a 5-40 T6 oil helped this issue, but it still did it occasionally. I don't really cold start it unless it's plugged in for a while. Just wonders if I should try to address dirty injectors.
3. Lumpy Idle, only occasionally
Just cold started it tonight after sitting for 2 weeks in -20 weather, plugged in. No stiction, and it idled quiet and smooth. After 10 minutes of driving, when I idle again, it's kinda lumpy. I wouldn't call it a surging idle, it's a little slower than that; the exhaust sounds fine but the engine rocks a little bit and moves to a 1,2,3,1,2,3,1,2,3 kinda rhythm when it's normally 1,2,3,4
4. LOTS of eye-burning, white smoke ONLY after excessive idling in cold temps ONLY when revving engine in neutral
Again, this might just have to do with temperature. My theory is that the temp is so cold and the cooling system goes so hard that I'm cooling off the cylinders. Just tonight(and many other nights) I was slowly creeping around parking lots for ~7 minutes looking for a parking space, and tried to test this theory. I revved the engine to about 2300rpm and it was smoking a bunch. Fuel smell. Does this every time I excessively don't put load on the engine for a long time. Never rolls coal or white or blue under load, though. It burns clean. It DOES smoke pretty white and sometimes slightly mixed with blue on a cold start, but only for 5 minutes and it's gone when I start driving.
5. Throttle response?
This one might just be because I'm new to diesels and the compression is INTENSE, especially with a manual trans. But I feel like I can't really get driving around unless I'm like 40% throttle. If I'm driving in the mountains and let off for a hill, it takes quite a bit of throttle input for the injectors to start firing again, and when they do, it's not gradual. The injectors are just kinda on and off. It leads to jerky throttle applications.
6. BLOWBY
When it's cold, it smokes out of the oil filler hole as well as the dipstick tube. It's just a little waft of very atomized oil. Flipping the cap upside down it does not move at all, and holding my hand over the filler hole yields no excessively bad pressure. It's there, but for 330k, my dad's 80k mile kia has 3x worse.
Sorry this was so long worded, but I figured I might as well get all my engine questions answered. I very well might be just super paranoid, and I know I'm a bit insane for buying a diesel in the coldest area in my state, but I still know that something isn't 100%, but also know that such an old clapped truck will never be 100%. Any input, whatsoever, when it comes to repairs, things to look for, maintenance, etc would be GREATELY appreciated.
Thank you all for your time,
Sean
2. Stiction?
6. BLOWBY
Sean
