Recently put a used motor in my truck and decided to leave the injectors it had in there because i was told they where new, surprise surprise they probably the ones it came with in 1999 and doesn’t like cold starts, same symptoms an old set. Of injectors had in my previous motor, The new motor is also an e99 with 2001 electronics so I figure its best to put my newer 01 injectors back in, maybe even pick up a few extra ponies free of charge. I did this job once before and and after install it was hell to get it started back up so i wanted some insight on what all i should do to prime it. Ive heard fill hpop res, but from what I understand thats low pres. oil and just feeds the high. I plan on cranking w/o glow plugs for a while to get some oil in the logs as well, but how long ive heard 5x5 up to 10+ times and for longer. Also what opinions do you guys have on filling rails up from the drain ports so it doesn’t need to fill up such a large volume to begin with?
