1 - 8 of 8 Posts
Hey there my power pedals only move about an inch if that... Has anyone ever had this problem, an is there anyway of fixing it? Thanks for your time...
Discussion Starter #2
Please help
:bump::icon_ford::bump:
:icon_ford::bump: someone must have had this problem before come on fellers...:bump::icon_ford:
Mine is doing that too. I found mine to be the gears inside the brake pedal are screwed up so I will have to replace mine. You can get under there and pull out the small drive lines to each pedal to see if its a pedal problem or a motor problem.
Ok thanks for getting back to me man, I will give that a try in the morning... Hopfuly i can get em working again, because im 6'5'' an my girfriend is 5'6'' so she likes to use them...
Did it work out ok for ya?
No man im sorry everytime i went out to take a look something else would come up... Now i just got flown up north to work for a few weeks... When i get back to my truck i will make sure that i take a look at them an let you know hoe it goes... Thanks Again...
1 - 8 of 8 Posts
