21 - 40 of 43 Posts
1985 F350 Crewcab
Discussion Starter · #22 ·
Next up is rear axle swap.
I first also wanted to swap rear leave spring, but EX have less payload than F350 so I don't thing EX springs will be great.
It sucks because EX leave springs are in mint condition
Axle on Bullnose
Automotive tire Motor vehicle Automotive lighting Bumper Automotive exterior
Axle from EX
Tire Automotive tire Motor vehicle Wheel Tread
1985 F350 Crewcab
Discussion Starter · #27 ·
It's not easy and it takes a lot of more time than I expect.
We have a retailer i Sweden for Dakota Digital. I'll need to talk to them about several things. Got no ABS module and I need to get amber signal / turn lights.
1985 F350 Crewcab
Discussion Starter · #28 ·
Motor vehicle Automotive tire Vehicle brake Wood Gas
It was a lot of work to make it fit.
Can't close the hood🤣....
Fuel heater is in the way.
???Is it possibly to delate/remove the fuel heater??? Or does it make the engine run better???
Administrator
1985 F350 Crewcab
Discussion Starter · #32 ·
Great thanks 👍😁
1985 F350 Crewcab
Discussion Starter · #34 ·
Next steps on the to do list
•take care of som broken bolts in up-pipe collector
•Make fuel lines longer.
•Get the frontclip 12" longer to support radiator
•Put all wiring to the right connections
•change all filters
•try to start her up
Your username is intriguing to me
I live below a mountain called flatiron, and it has black marks from low flying aircraft
Holy crap! Near Lost Dutchman??
1985 F350 Crewcab
Discussion Starter · #36 ·
Hi!
I wrote that this part was the fuel heater....👇
Automotive tire Motor vehicle Vehicle Automotive fuel system Automotive exterior
Brown Automotive tire Wood Alloy wheel Rim
But I think everybody means this...☝
So my Question is...
Can I remove the part on the first picture?
And that is also a fuelheater?
21 - 40 of 43 Posts
