The foil delete will not give you any more power. It just looks better, and some say you can hear the turbo a little better. Just start peeling the foil off, and take a razor blade and scrap till you get it clean. I did it, and it wasn't as bad as i thought it would be. The AIH is cheap, and it gives you better airflow. The 10k mod gives you better throttle respond. some say it doesn't with the chip, but i did the mod anyways. You can mod the IDM, thats good for 20hp, but be carefully, you have to unsolder, and solder in a resister, i was going to do that, but when i found out how much a new IDM is, and the parts in there are so small, i said i'm not going to take a chance. You could also do the FPR shim, that gives you more fuel pressure, but you should have a gauge when you do this, cause you don't want your pressure to high. You can get those gauges that go under the hood, its gives you better throttle respond, i don't know about hp. you can unplug your wastegate, less turbo lag. thats all i can think of now, anymore questions just ask:thumb:
