1 - 13 of 13 Posts
My power sliding rear window doesn't close, all the other windows and the sunroof do work, what could it be? No noise from the motor or anything.
fuze maybe?
I checked the manual and there's a fuse for the power windows, delayed accesories, sunroof, etc... the door windows and sunroof still work, wouldn't the rear slider be under the same fuse?
The fuse looks to be good, and all the other windows work. What else could it be, now I'm going to check if the motor is getting power, if is is then its the motor.
It's the motor, anyone know the part number?
Yes it is.
I wanna see the new truck!!!wheres the pics
Its in the garage, not registered yet, so once I take it out I'll take some pics.
Ok, here are some pics.
Discussion Starter #11
Anyone know how to remove window tint? The back glass is way too dark, almost spray painted black, and I want to remove it.
Any resolution?
I was drivin my shiny new F250 Stroker home today from the dealer, messing with buttons and opened the back window. It wouldn't close! Two fuses were blown when I cracked the fuse box, replaced those and still wont close!
Did you end up having to replace the motor? Anyone know how to get the window closed in the meantime?
Thanks!
Trevor
Busted out the electrical tester. Bad "Close" switch, open side works fine.
Thanks,
Trevor
1 - 13 of 13 Posts
