1 - 20 of 22 Posts
Home & Community
How do I attain greater power for towing with the following in mind:
1) Hydra chip and cold air in an otherwise stock 2001 7.3 F350 Crewcab 4x4 long bed
2) New factory rebuilt Ford Trans
3) Towing a 20' Hybrid camper about 6,000 lbs with gear.
* Don't need a race truck....would like to go up a 6% grade with relative ease?
4" exhaust, KC 63/73, and 160/0, 160/30, or 180/30 injectors, and gauges or CTS3.
Reactions: stratertele
If you look at my signature I have the same truck as you.
I run a Hydra with stock tunes, CAI, 6.0 trans cooler, I just installed a 4" turbo back exhaust.
You will want/need monitoring for your systems and I love my Edge CTS2.
You can always spend $ for more power, but I tow a 12k lb 5th wheel and have no problems with my setup.
Eventually I will upgrade my turbo wheel
Boost, EGT and trans temp gauges, leave the Hydra on stock you'll you get those, the get a 4" exhaust and a billet compressor wheel.
Home & Community
Thanks, I do have the Edge computer and Hydra!
1) Which tune did you download that you use for towing?
2) When you hit a grade and put the trans in tow/haul mode what RPM do you run the engine at?
3) What is CAI?
4) Did you notice a difference with the 4" exhaust?
Appreciate any reply,
Gary
Home & Community
Thank you for the reply,
What difference did you notice with the Billet wheel?
I stayed with the PHP recommended stock tunes for the different types of driving.....
For my 5th wheel I use the 40hp tow tune (10k-12.5k lbs) 40hp isnt huge, but there is a major difference in the trans shifting and torque converter lock-up
When climbing and the overdrive kicks off, my speed is around 55-60 which puts my rpm's about 23-2400 and my truck just purrs and it leaves me room to speed up or slow down a little as needed depending on traffic.
3) What is CAI? Cold Air Intake
Yes, it did lower my EGT's about 50-80 degrees and not any louder than stock
Gary
Quicker spooling and no turbo surge, I highly recommend a billet wheel if you have aftermarket tuning, turbo surge will kill your turbo pretty quickly.
Home & Community
Discussion Starter #11
To oilcan101:
"For my 5th wheel I use the 40hp tow tune (10k-12.5k lbs) 40hp isnt huge, but there is a major difference in the trans shifting and torque converter lock-up"
This was of great help camping/towing this week!!!
To oilcan101:
I’m really happy to be able to help someone else after all the help I have received on this forum
Home & Community
Discussion Starter #13
I bought/installed the following when I purchased the truck:
  1. CAI
  2. Hydra
  3. CTS2 and EGT probe
  • My TFT is running a high of 194 (what temps are you getting before and after the 6.0 cooler which I'm considering)?
  • How did the 4" exhaust change things for your rig?
TIA,
Gary
  1. CAI
  2. Hydra
TIA,
Gary
I live in AZ where it's a little warm in the summer and my trans temps were very high before installing the 6.0 cooler.
Before 6.0 cooler - in the summer, running up hill, pulling 5'er, trans temp= 200-220 deg (sometimes more)
After 6.0 cooler - under same conditions as above = 170-180 deg (sometimes 195 in stop & go traffic because TQ not locked)
The 4" exhaust only lowered my egt's 50-80 deg. I was hoping for more, but it's difficult to cool anything off when it's over 105 ambient temp
oilcan, do u know what your gearing is?
00t is correct.
And I have 3.73’s
If you’re cruising at 2k rpm and speed is about 71 you have 3.73 gears also.
The 4:10 will be about 2400 rpm at 70 mph.
This is from my personal experience driving both.
I think I had put that question out there before as to whether anyone had went from the 3.73 to the 4.10. I have always felt that with my set up and various trailers that I pull, that it would help my bottom end with this truck. Even coming up on boost a little quicker with the truck running a few hundred rpms more at highway speeds. I think once upon a time I did read some ones post that did this and he was very happy with the move.
I think Ford used the 4.10's in all the dually's because they were expected to be tow rigs. If you tow heavy a lot the 4.10 ratio will definitely get you off the line easier and keep you in the power band sweet spot more while on the freeway but you will sacrifice some top end cruising/economy when not towing.
1 - 20 of 22 Posts
