Hey all,
I've found what I think I want, and put a deposit down on it. I'm going to head out there this weekend to test drive it, and check it out, however, since this is my first Powerstroke, I'd like some input from the experts if possible... that's you guys :thumb:
I'm taking a Scanguage II with me on the test drive to check ECT and EOT Delta, I've already learned that much. Going to take a copy of the Ford Bulletin to back me if it is above 12 degrees, that it is a problem. Can't count that it has the latest flash to throw a wrench light itself.
Here's all the pictures I got sent to me of it:
Photo Album - Imgur
A few things I already noted:
It looks like it was broken into already, the driver's side lock looks a little deformed below it, as if it was popped, as well as the trim around the radio looks like a radio was pried out with a screwdriver.
The Tailgate has been repainted to 'factory new' according to the dealer since these pictures were taken, he didn't have any new pics since then.
The Passenger front quarter panel has 2 small bumps in it.. I wouldn't call them dents, because they're barely there.
The Tires are low and will need replacing soon.
Is there anything else that I'm missing that any of you see? I don't specifically know what to look for in the engine compartment pics, to see anything blatantly out of place.
What other things should I check when I take it for a test drive? Obviously I'm going to test every single thing I can think of, but anything specific that most people wouldn't think to check/test when checking one out, that needs to be checked, other than the above?
Thanks for any help!
Photo Album - Imgur
