1 - 10 of 10 Posts
Well just like it says... I am wondering if I can assess the relay to trigger the reverse lights from under the dash... Anyone know? I know it is there but don't know what to tap or which wire to tap to trigger the relay. I was just trying to tap into what the truck already has instead of adding another relay and running a wire all the way to the rear.
Purpose??? I want to turn on the reverse lights manually to make it easier to hook up trailer and dock boat..
I know this probably doesn't help.....but....why don't you just get some cheap $15 lights from Pepboys, and mount them under your rear bumper?
like this:
I already have a set of 55w under frame on hitch mounts, then I have a LED bar with reverse LEDs and finally the factory lights, soon to be replaced with LEDs, so I have the light, I am just looking for a way to trigger the factory relay. (which wires to tap into)
There should be a wire for that on the 7 pin connector of the trailer wiring. Why not tap that? Its already at the rear of the truck.
Good idea! and you could probably just trigger the led line of fire bar to come on, and that should give you enough right?
what I am trying to do is trigger the relay INSIDE the cab, in the FUSE panel to activate the trucks reverse lights, I already have the bumper, LED, and factory reverse lights all wired and working properly, I am just looking for a way to trigger the FACTORY relay to turn them all on. ie: when you put the truck in REV. - but i want to put a toggle on it to turn them all on w/o putting the truck into REV.
There is a wire you can tab into right next to the fuse box, Ill look under my dash tomorrow.
Sweet... I had looked but couldn't figure it out... didnt know which one would tell the relay to actuate....:dunno:
2002 f350
I want to do the same thing as lifsvr7 on a 2002 f350? is it pretty much the same? I just bought this truck and have had a brand new box of fog lights for 5 years and never installed them on anything until now. Definitly need more light backing up into the driveway so i don't hit the old lady's BMW or our driveway lights......its a small driveway makes for a little tight fit.
:usa:
1 - 10 of 10 Posts
