I’ve been trying to figure out my mpg issues for awhile now. Hand calculated on the last couple tanks I got about 13 mpg with mixed driving. The only time I get decent mileage is when it’s all highway running 70 in my hottest tune in which I see about 15 mpg (currently 1023 diesel Cummins killer tune but previously was 120hp race from php). I thought it might have just been winter fuel but it’s gone through several tanks during summer with the same results (this started last winter). I used to see up to 20 mpg on a highway trip easy without being easy on the throttle
So I was sure I had a boost leak/exhaust leak. I did end up finding my up pipes had a slight leak and I replaced them with full force up pipes, boots weren’t leaking but I went ahead and put on all new riff raff boots and new intercooler pipes, along with a wicked wheel, deleted the pedistal at the same time. Truck seems to make good power but the mpgs are still down. Reading up to 25psi boost on edge monitor.
Truck is an 03 7.3, stock suspension, 305/55r20 tires, edge cts2, hydra with 1023 tunes, wicked wheel 2, stock hpop, 5 inch exhaust, 6637 filter.
I‘ll note I did clean the ebp tube and sensor. put in a new motorcraft cps sensor in awhile back.
curious to know some others thoughts experiences. At this point I’m wondering if I should look towards hpop?
Thoughts and suggestions appreciated.
