Hey guys and gals I am in need of some help. I have a 2004 F-350, 6.0 Power Stroke Diesel with 101,000 miles on it. It has been completely bulletproofed with new head gaskets and ARP studs installed at around 50,000 miles. Now it has a damn coolant leak that appears in the driver side front wheel well. The thing is, it only leaks when I am pulling a load with it. Without pulling a trailer, I could drive across country and it wouldn't leak a drop.
I took it to my mechanic for Round 1 and he found a cracked hose. Damn I was happy it only cost me $37. Until I hooked up my trailer..... and it leaked again.
Round 2 he replaced the coolant reservoir. It wasn't as cheap as Round 1 but still only around $250. That wasn't bad either, but pulling a load it continued to leak.
Round 3 and the most recent, he said that he believes it's the head gasket and leaks when the engine is under the pressure from the load (trailer).
This is like hearing that your kid isn't athletic. It's hard to accept with the ARP studs and no water in my oil.
I am open to any suggestions before I spend $4000 replacing the head gaskets.
Thank you in advance for your input.
